valence mounts
  • long tall eta
    • Jul 2010
    • 1536
    valence mounts
    guys, what is the best compound to use to remount the far end brackets to the valence. the ones that are epoxied to the valence. and where can i get it?
  • klavender1
    • Apr 2011
    • 400
    Maybe check out local stores that supply body shops and get some 2 part epoxy. They should be able to tell you what works good.
    • td325ic
      • Feb 2006
      • 788
      Pretty much any epoxy that works with plastics will do the trick. I use Devcon Plastic Welder and has worked well for me. I get it at Orchard Supply.
      Just prep the surface beforehand. Scuff the area with like 40grit or 60grit so the epoxy has something to grab onto. Clean all dirt and oils with something like denatured alcohol or 91% or higher Isopropyl Alcohol.
