Trunk lid on Vert adjustment?
  • dunebuggyjay
    • Nov 2011
    • 257
    Hi guys, I have an 88 Cabrio, and mt trunk lid is sticking way up on the drivers side. (same side as single shock to hold it up)
    Is there any way to adjust this? I tried adjusting those rubber feet on it, which made it better, but its still sitting pretty high. I even took of the shock to see if that was pushing it up, and it still looks the same.
    The wierd thing is when I was looking for an e30, I looked at 3 other verts, and they all had the exact same issue. Some worse than others. I may try and adjust the striker latch down tonight to see if that helps.
    Anyone other vert owners have this problem, or know how to fix it?
    Thanks
    Jay
  • OnMy2ndE30
    • Sep 2011
    • 385
    I have that issue now, but it occurred after a buddy of mine on here and I swapped on an "is" trunk lid from a coupe onto my vert for my 3rd brake light delete mod. There is a shim on the passenger side between the lid and the arm, but none on the driver side. I will have to look at it closer and see what I need to do to fix it. If I figure it out, I will let you know.....
    • fporro
      • 1860
      later cabrios came with dual shocks.
      Zinno has 89 and up 3rd light delete with an iS, it fits very well.
      Delphi has original lid
      • alreadyRogue
        • Nov 2011
        • 135
        What you can do is on the driver side of the trunk lid where there are two bolts connecting the lid to the hinge arm, unbolt the upper bolt and use two washers between the hinge and the lid. Then put the bolt back in through the hinge THEN the two washers and tighten it down.
        If it is still lifted, add another washer, if it is pressed two far down, remove a washer.
        Good luck.
        • scottinAZ
          • Dec 2009
          • 1312
          adjust the hinge to body mounting point. you can access this through the top storage compartment. Just had to do this on my vert, easy to do, takes about 10 minutes.
          I saved 15% on my Bimmer parts by switching to ...
