Door locking issues
  • TheTacoMan
    • Nov 2011
    • 2308
    Door locking issues
    Im having an issue with the driver side door locking/working at all. I purchased the car about two weeks being told the driver door didnt lock but the "door" key only works on the driver side. Car will not lock from trunk or passenger side or even turn. Whats the best way to replace this? Three new locking cycls for trunk and both doors with new key for the entire car or just replace drivers door?
  • dogsbark26
    • Nov 2008
    • 533
    What?
    It sounds like ignition and driver door lock cylinders were changed to a different key. Does the key you got work in the glove box lock?
    First, get rebuild kit for driver door lock. Rebuild driver door lock. Then work on rest of system. You will have a much better understanding of how the locks work after rebuilding one lock.
    You will be able to re-key the other lock cylinders to fit that key if required.
    What good would replacing the door do? Another key? So one for driver door and another one for ignition?
