Polishing bumpers how to?
  • agent
    Vice Grand Pubaa
    • 7960
    If you sand the anodization off the bumper, it will require exponentially more cleaning and polishing once you do. The best solution I've found is the deoxidizer product from Classic Trimcoat. There should be some pics in my build thread.
    Originally posted by kronus
    • Keith M
      • 2338
      Originally posted by camip
      Broke and just got out of high school but hell no I don't want to sand.
      If you don't like sanding, do not attempt this. I've heard it takes 80 grit to remove the anodized finish and you will have to sand with progressively finer paper, removing all sanding marks before you can polish. It's a very time consuming project and if you don't take the time to do it correctly the results will be less than satisfactory.
      • JasonC
        Site Manager
        • 14451
        Paging Forcedfirebird to this thread!!!!!!!!!
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • gp.plus
          • 416
          Oven cleaner works well to remove anodizing in most cases, you may have to play with the times a little, could take 5 min could take 2 hours. I have had good luck with easy off in the yellow can on some bike parts in the past. Don't panic if the aluminum starts turning a dark color, this wipes right off with CLR.
          • camip
            • Nov 2011
            • 1253
            I think I'm gonna try some of the oven cleaner here soon and report with pictures.
            • E30_Pare
              • 7801
              That may work on light anodizing, but don't underestimate how thick it is on DB's. Could probably measure it with a ruler. LOL
              DREWLIENTE
              1$ PShops PM me
              • camip
                • Nov 2011
                • 1253
                Well fuck it then. I ain't polishing nothing.
                • Holland
                  • Nov 2008
                  • 7212
                  Strip, sand, polish, clear, profit.
                  Originally posted by DEV0 E30
                  • V8E30
                    • Jun 2012
                    • 75
                    going at it this weekend ill let you guys know if the oven cleaner works
                    and how long i let it sit
                    • jw 325ic
                      • Sep 2006
                      • 1360
                      Interesting. I tried several metal polishes and like someone above said, it only did so much. Looked good from a viewers distance but up close it still wasnt perfect. I ended up painting them...sometimes i feel like finding another set of 88 bumpers and getting the chromed...hmm. Waiting for some pics :)
                      • V8E30
                        • Jun 2012
                        • 75
                        how to is up and the afters as well hope you guys enjoy
                        • camip
                          • Nov 2011
                          • 1253
                          Where at?^
                          • V8E30
                            • Jun 2012
                            • 75
                            first post page 1
                            • slaterd
                              • Jul 2011
                              • 1731
                              Oh my gawd mount that shit! Get picks with close ups!
                              Originally posted by Wh33lhop
                              This is r3v. Check your vaginal sand at the door.
                              • gp.plus
                                • 416
                                V8e30.. Looks great man! I was afraid you would run into that problem with the oven cleaner, like pare said it is very thick on those bumpers, i have only ever used it (succesfully) on bicycle parts.
                                If you use more varied grits of sand paper between 400 and 2000, youll get even better results. It is very hard to get out the 400 scratches with 2000, in the least use 400, 800, 1500, 2000. Always be sure to clean your bucket and start with fresh water when changing grit..
                                Looking forward to pics on the car,
