How to Clean Yellowed Containers in Engine Bay
  • rscheiring
    • Jan 2004
    • 1014
    Anyone know how/if the yellowed plastic containers/resevours in my engine bay, for things like coolant, ww fluid, etc, can be brought back to white?
    TIA, Rob
    A great pleasure in life is doing what people say you cannot do- Walter Gagehot
  • Sean
    • 5793
    If you could, you'd have to clean the inside. I think the only way to get those pretty again are to just buy new ones.
    Those coolant resoviors in Pre88 E30's are REALLY ugly! :x
    - Sean Hayes
    • Chris E30 Cab
      • 866
      buy new ones...they are pretty cheap and if you paint them they will only chip and not look too good ;)
      • LikeCDoos
        • Jan 2004
        • 2522
        but if you paint them you can't check your coolant levels as easily
        • bimmerphile
          • 3495
          yeah there is a reason they are translucent like that.
          • BingM3
            • 863
            If you buy new ones, they will be in white color as I had replaced mine a year ago.
            • AdamF 88iS
              • 2051
              The yellowing is due to some solvents and chemicals in the plastics evaporating out over time. It's not a matter of cleaning. Get new ones.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • rscheiring
                • Jan 2004
                • 1014
                Thanks all. I be buyin!
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  You can always dye them. That type of plastic dyes quite well with Rit die. I dye my go-ped fuel tank all the time with Rit die. Works great and you have a full range of colors to choose from. Don't worry about it flaking off or anything too because it doesn't leave any residue behind. It just colors the plastic. I would suggest letting it sit in a bleach solution for a day or so before though to get it as light as possible.
                  Andrew
                  • Fred
                    • 659
                    If you buy it new, it'll turn light yellow in about a year or so.
                    '86 325 2.8i stroker - Arctic Blue
                    '11 328i Sports Wagon - LeMans Blue
                    Strictly Eta
