Any ways to prevent rust on the brake hub surface?
  • Jonathan M3
    • 1837
    I have some new Balo rotors for the M3 and wondered if it was possible to mask off the disc surface and paint the other areas of the rotor with a high temp paint or protective coating. I'd just want to paint them something neutral like silver. Anyone tried this?
    '05 E46 M3 Imolarot/Cinnamon - CURRENT
    '98 E36 M3 Estorilblau/Dove - SOLD
    '90 E30 M3 Brilliantrot/Black - SOLD
    SRS BSNS Motorsports - 24hrs of LeMons Racer
  • Jordan
    • 12913
    yes, yes, yes
    yes to everything
    yes
    https://mtechniqueabs.com/
    • Ryan Stewart
      I Love Miatas
      • 8978
      Mine still look sliver after 20k miles. I made sure and cleaned the hubs with an alcohol solution because there was a cosmoline like rust preventative on them and then did multiple layers of sliver. A bunch of thin ones of paint for exhaust manifolds.
      Masking was easy because i just used the cardboard supports that came in the box with the rotors.
      Im now E30less.
      • bimmerphile
        • 3495
        Just apply WD-40 regularly, duh
        • darien28
          • Jan 2004
          • 240
          i painted mine w/o any problems...
          I'd be more worried about the hubs and the rotors siezing to the hubs... as I had to use my emergency jack braced against the frame to literally pry my front rotors off... and when tehy did pop off, they flew ~3ft. :x
          • Jordan
            • 12913
            smear a thin coat of antiseize on the hubs before you remount the rotor and that wont happen again.
            but yeah... i had one rotor on my car that i beat off with a hammer, warped the shit out of it but it finally came off.
            • mgold
              • 709
              On his M3, Dave Adams sprayed on the rotors a brake rotor and pad treatment, which you can spray directly on all parts of the rotors and pads. It works as an anti-squeak but is nice since it also prevents the rotors from turning rusty. I believe he said it was from Würth. Here's a couple of pics.
              • Sean
                • 5793
                Those look REALLY nice. THat was my plan as well.
                Anyone know exactly what Wurth paint he used?
                I'll be goin on a hunt in a bit to see if I can find what he used. Thought I'd ask though. ;)
                - Sean Hayes
                • Low Level E30
                  • 1646
                  Why would you paint the rotors like that? Surely the paint will come off when you use the brakes? Or... not?
                  • mgold
                    • 709
                    The paint does come off when you start using the brakes. My understanding is that particular paint is designed to help the brake pads bed in correctly. It will wear off of the rotor and what it leaves behind (where the pads don't make contact) will protect the rest of the rotor.
                    • Spaz
                      Crazy Canuck
                      • 2276
                      exactly, but imo if he has race pads they will squeal no matter how much anti-squeal you put on.
                      Cam .W '91 325is
                      Spaz's 1991 Alpine White???? S52 Build Thread...
                      • Beej '86 325es
                        • 2639
                        Yeah, the paint comes off the braking surface right away when you start braking. I have some cross drilled Stillen rotors that are cadium coated, the coating just all peels up into chunks the first time you drive it, but then everywhere but the actual surface is completely protected afterwards.
                        -Brandon
                        '86 325es S50
                        '12 VW GTI Autobahn DSG
                        '03 540i M-Sport (sold)
                        '08 Jeep SRT-8 (sold)
                        For sale:
                        S50 TMS chip for Schricks
