What to use to strip paint off manifold & valve cover?
  • Jand3rson
    • 37587
    I'm going to remove my intake manifold and valve cover soon, and get them ready for powdercoating. What should I use to strip the white paint off put on by the previous owner? I don't know what kind it is, but it looks pretty cheap.
  • bimmerphile
    • 3495
    Soak the bitches in acetone, then paint thinner, then mineral spirits.
    Yup, that should do the trick. $8 from home depot too :-D
    • Jordan
      • 12916
      Just goto Bimart and buy yourself some JASCO paint stripper.
      The paint will bubble up, and you can wipe it off with a rag. Flush the residue off with acetone.
      Thats how i cleaned up that AFM adapter, and it worked nice.
      https://mtechniqueabs.com/
      • AndrewBird
        The Mad Scientist
        • 11898
        Also, for the hard parts, use a wire brush to scrub anything off. At Miller Lumber you can buy acetone and such in gallon containers for real cheap, if you want to go that route. Jordan seems pretty confidant in his product though.
        Andrew
        • darien28
          • Jan 2004
          • 240
          how about just bead blasting it.... much faster and cheaper. just ask a local shop to let you use their blaster for a few bucks.
          • Rob
            • 8166
            bead blasting or a few minutes with a wire wheel
            BEERTECH
            • AndrewBird
              The Mad Scientist
              • 11898
              I wouldn't use a wire wheel. That will make the aluminum all wavy looking if it heats up too much..
              Andrew
              • ChocolateKrackers
                • Mar 2004
                • 233
                When in doubt I used soap and steel wool.
                "My backpack's got jets..."
                ~MC Chris is my co-pilot~
