Are the fog light cutouts large enough to be able to pull the fogs through them? As in, can you remove and replace the fogs without going from behind?
Question for anyone with M-tech2 valence
Re: Question for anyone with M-tech2 valence
i'm confused... the foglights are bolted in from behind... and are removed from behind on the later style valence.Originally posted by MystikalAre the fog light cutouts large enough to be able to pull the fogs through them? As in, can you remove and replace the fogs without going from behind?
m-tech II valence is only a skin that goes over the front end. -
the mtech II front does not overlap the fogs. I have a pic around here somewhere...
EDIT:
My mountains are better than yours.Comment
