My girlfriend's Honda's driver and passenger windows have so much water spots (at least 2 years old) that it's hard to see out of sometimes. Someone suggested using nail polish remover to get it out, but that hasn't cut it. Anyone have any suggestions?
Removing water spots from glass
Tags: None -
Originally posted by kencopperwheatOriginally posted by bimmerphileHCl
That will do the trick.
I've heard of people using coca-cola.
For the phosphoric acid.
You know, have you tried white vinegar? Acetic acid, though weak, might be enough to at least loosen the spots.My mountains are better than yours.Comment
White vinegar or Coke, eh? Maybe I'll try that tonight. Thanks guys, I'll let you know how it goes.Comment
Originally posted by FredWhite vinegar or Coke, eh? Maybe I'll try that tonight. Thanks guys, I'll let you know how it goes.
Go buy some habaneros, cut them in half, and rub the hell out of some water spots.
Naturally, wear skin and eye protection.My mountains are better than yours.Comment
Super fine steel wool with a lot of soap for lubrication. Polishes up nicely; the sprinklers at the dealer I used to work at caused us lots of problems with this.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Originally posted by bimmerphileOriginally posted by FredWhite vinegar or Coke, eh? Maybe I'll try that tonight. Thanks guys, I'll let you know how it goes.
Naturally, wear skin and eye protection.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
Originally posted by kencopperwheatOriginally posted by bimmerphileOriginally posted by FredWhite vinegar or Coke, eh? Maybe I'll try that tonight. Thanks guys, I'll let you know how it goes.
Actually, capsaicin is caustic
and only pussies get burned :twisted:My mountains are better than yours.Comment
Bon Ami window cleaner applied with a #0000 steel wool pad. Make sure it's #0000 and not #000. You can get the steel wool at most hardware stores cheap. The Bon Ami window cleaner is sold at $0.99 Stores in CA. You could substitute another window cleaner though.Comment
Bar Keepers friend. Its glass countertop polish but it doesnt have chemicals or bleach in it so it wont fuck up your paint if it touched it.Im now E30less.
sigpicComment
