Help me with some balls to the wall detailing
  • bimmerphile
    • 3495
    Originally posted by NitroRustlerDriver
    I cut and polished my MG with this stuff that Myguirar's (Yes, I suck at spelling.) makes. It's called diamond cut. It's both a cutting commound and a polish in one and as you use it more, it begins to polish and take off less and less. About $15-20 for a bottle big enough to do my car, might need 2 on an e30.
    Andrew
    2 bottles of cut/polish on an E30?
    Jesus christ. Those must be some small ass bottles.
    • kencopperwheat
      King of Kegstands
      • 14396
      Originally posted by bimmerphile
      Originally posted by e30sam
      What have you guys found that works best on vinyl interior? Dashboard? Procedure?
      I didn't do my seats and dash for a while so I did it with Magueres Vinyl and Plastic cleaner. I let it sink in for about 10 hours. seats turned out great, but dash not so great.
      I've always used armor-alll on the dash, and Vinylex (Lexol's stuff) on seats.
      I've become a very big fan of the Armorl-All wipes. It's so much easier to use them than the spray bottle and rag. And the wipes are able to get into every little nook and cranny in your car. I highly recommend them.
      Originally posted by Gruelius
      • e30sam
        • 170
        To get in all the nooks and crannys I use a clean paint brush. It is sweet what applying to vinyl seats to get in all those deep little holes. I have used vinylex before on both seats and dash and it works far better than magiueres.
        • bert
          • 306
          careful with those Armour All wipes...that stuff is bad news
          for vinyl...petroleum content will dry out your vinyl surfaces
          and cause them to crack...
          regarding exterior products...i have tried them ALL on my
          e34 show car and the best stuff i have come across is not
          expensive mail order stuff like Griots...i've had the absolute
          best results hands down with the Perfect-It products from
          3M...used to only be able to get them at Paint and Body supply
          stores, but now you can purchase some of the line at Pep Boys...
          i've used quite a bit of the Hand Glaze in the past to remove
          scratches and swirls, but most recently i have started using
          the Fine Cut Rubbing Compound and Swirl Remover for dark cars
          with a foam padded random orbital buffer and the results are
          awesome!
          i had purchased some of the Griots Machine Polishes and spent
          about 2 hours trying to get my hood looking right...i switched to
          the 3M products and the hood was completed in about 15 minutes...
          Zaino products are pretty cool as well...the finished result is probably
          comparable to other products out there, but Zaino doesn't discolor
          plastic and vinyl if you get it on those surfaces by mistakes and it
          doesn't dust at all when you buff...that saves a bunch of hassle--
          especially on a black car...
          good luck...and let's keep 'em clean and detailed!
          bert
          • AndrewBird
            The Mad Scientist
            • 11897
            Andrew
            I used all but about 1/10 of a bottle on my MG. I figure it will take a little over a bottle to do an e30 if you are going to go over the whole car THROUGHLY.
            On another note, when I did my MG, I did some parts twice just to get a little more shine since the paint was old and bad. If the paint is good though, 1 bottle should be fine.
            Andrew
