removing side moldings?
  • e30evolution
    West Werks
    • 1888
    i have a 90 325iS and i want to remove the side moldings so i can buff under and around them, and also repaint them..... i know they are held on with clips and should pop off..... but before i start, what is the easiest way to remove these without damaging the paint surface
    http://www.westwerksauto.com
  • LikeCDoos
    • Jan 2004
    • 2522
    open your doors and unscrew the small bolts. There will be 1 per molding (I think). then be carful and either slide them back or pry them off the small plastic clips. Becarful because these break really easily...i broke one of mine.
    • e30evolution
      West Werks
      • 1888
      i am guessing you can buy new clips from the dealer... i need one for my front molding, it is only held on with one clip.... thanks for the info
      • e30evolution
        West Werks
        • 1888
        how about the rear side moldings?
        • Spaz
          Crazy Canuck
          • 2276
          some clips you cna buy...some you can't as it comes with the molding and thats the only way of getting it :S
          i'm in a struggle wiht that right now.
          Cam .W '91 325is
          Spaz's 1991 Alpine White???? S52 Build Thread...
          • LikeCDoos
            • Jan 2004
            • 2522
            the rear one just pops straight off without any small bolts. Just get ahold of it and pull straight out...do not do that for the front 2 though.
            • e30evolution
              West Werks
              • 1888
              sweet...... thanks
