The rear of my car is still up too high..
  • bimmerlover
    • 424
    I've put H&R sport springs on my 318.. lowered the front perfectly. I love it. But the back is stillllll too high. My brother wants me to cut a coil off the rear springs. Has anyone done this? Have any advice?
    Thanks
  • Nick325is
    • 1409
    Don't cut the coils. You can always remove the rear spring pads or get some thinner ones.
    Nick
    • bimmerlover
      • 424
      Hm.. I'm not too familiar with that idea. About how thick are those spring pads?
      What can be the problems with cutting the coils?
      I'm still learning..
      Thanks
      Rachel
      • Kavkazia
        • 394
        Take a good look at your rear spring, and you'll notice why it cant be cut.
        Like Nick said, you can remove those spring pads, and lower it about 1/2 or so. If it will be still too high for you, I suggest going with different spring setup, and selling yours or something.
        95' M3.
        90' 325i Turboed.
        87' 325eS Fixed.
        • Nick325is
          • 1409
          You can stop by and take a look at my car if you want when I am back home and I will explain the spring pad thing. I am tucking tire now and i need to raise it some.
          Nick
          • Bill 84 318i
            • 1600
            Nick
            Silence. Your drop is perfect.
            • Jand3rson
              • 37587
              I think your car looks great, Bill.
              • BMW BMXER
                • 2325
                Go look at a rear e30 spring then if you still think it can be cut without problems cut it.
                Sold it.
                • Bill 84 318i
                  • 1600
                  Thanks Josh.
                  Rachel, this shot is a little bit biased because I didn't quite resize both sides to be identical (thought I did at first but it's pretty clear I didn't). It did lower it a little though.
                  It was from swapping these two pads.
                  Took me forever to get an even drop front and rear on my 318 though.
                  • e9nine
                    • 1890
                    :nice: Thanks be to the lord of drop that you don't talk about it as much as before.
                    • Nick325is
                      • 1409
                      Bill I still want the rear to sit up slightly higher. Otherwise I won't be able to run 225s on the current wheels.
                      • bimmerlover
                        • 424
                        Perhaps a couple of bags of concrete mix in the trunk would be simpler?
                        What springs would ya'll recommend that lower the rear of an E30 nicely?
                        • ///M42 sport
                          • 3952
                          after I blew out my rear shock mounts, the h/r springs got compressed and rode lower. enough so that there is no fender gap in the back. Also you might want to let them settle a little.
                          I have bilstein sports and h/r springs.
                          ________
                          Wendie 99
                          • Bryson
                            • 1490
                            heh, a full tank of gas... seriously, try it. with soft springs it makes a big difference
                            ground controls lower the rear nicely, to whatever height you think is nice
                            • e9nine
                              • 1890
                              If you're into car audio, dropping a sub and an amp will lower the car some more. You'd be trading off on some off the line acceleration though ;)
                              I'd say do the spring pads and stay with it till it settles a tad and you'll have to deal with it as it will be unfortunately.
