rear euro bumper removal
  • flawdaboi407
    • Mar 2008
    • 324
    How do I remove the rear bumper shocks? I have the bumper off and I removed the two bolt on each side that hold the shocks in but still wont come out. Are there more hidden ones...? Fast replys please, its getting dark! Thanks
    p.s There are three under the car and one on the passenger side in the trunk. 4 total. GOT THEM but still wont come apart.
    84' 318i m30b35 swapped!
  • hendrixvodu
    • Jan 2007
    • 2514
    ok....look under the car on the drivers side....you can see like the metal tunned ...if you know what i mean? that the shock is inside of...there is a bolt on the... pretty sure outer side of that...and the other side its in the same spot, its under the car there are 3 bolts to remove each shock
    -His-
    87 e30 325i
    87 e24 m6
    05 e83 x3
    94 e32 740i 5spd
    -Hers-
    89 e30 325i
    18 f48 x1
    • e30pwr
      • Oct 2007
      • 642
      or leave them in there and just drill like I did for the front and rears. Use baseball bat to even out. I just pushed the bumpers in initially and baseball batted them to the right tuck.
      • flawdaboi407
        • Mar 2008
        • 324
        do you have euro bumpers?
        Well I got them off... Now I have the euro mounts in the left hole on both side. Mounted them and it seems like thats where the mounts goes...? Put on the bumper and it looks stright. Am I right? Also the rear euro bumper leaves some gaps here and there. Needs a rear valance IMO. But its euro!!! So who gives a fuck. If you could help on the mounts that would be great. THanks.
        • hendrixvodu
          • Jan 2007
          • 2514
          if you have the same bracket i had then what i did was put one end in the hole, the bottom and the other top i drilled a whole into the trunk and it fit perfect...i also suggest on the sides where those ends go into the old hole for the plastic sides....drill that hole up about a 1/2 inch.......if you need more help fell free to PM me....here are all the pix i have to my rear to help you if they can
          heres how it should line up
          thats all i really have for pix...but i assure you it lines up very well
          -His-
          87 e30 325i
          87 e24 m6
          05 e83 x3
          94 e32 740i 5spd
          -Hers-
          89 e30 325i
          18 f48 x1
          • flawdaboi407
            • Mar 2008
            • 324
            Sounds like I have the same brackets you do! I put the 13mm bolt threw the left hole where the shock was mounted... then I drilled the 10mm right above it. I had to slot them out a bit so I can ajust them a little better. Same with the bumper mount. Im just going to slot them all for a perfect fit. Thanks for the help. I got it from here.... Thanks again!
            • flawdaboi407
              • Mar 2008
              • 324
              looks like you have me rims..... j/k.
              p.s im running a real german front licence plate from my brother inlaws e30 he had in germany. looks great! and the best thing its real not some crappy shit you got online or in the mall!
              • flawdaboi407
                • Mar 2008
                • 324
                Got the front on...
                • hendrixvodu
                  • Jan 2007
                  • 2514
                  wow lookin sick!!! did you buy them new??? they look new!
                  -His-
                  87 e30 325i
                  87 e24 m6
                  05 e83 x3
                  94 e32 740i 5spd
                  -Hers-
                  89 e30 325i
                  18 f48 x1
                  • hendrixvodu
                    • Jan 2007
                    • 2514
                    yea mine is real too its a temp plate from germany got it form a guy named Bourne on here....he shipped it to me from the homeland :D
                    -His-
                    87 e30 325i
                    87 e24 m6
                    05 e83 x3
                    94 e32 740i 5spd
                    -Hers-
                    89 e30 325i
                    18 f48 x1
                    • scabzzzz
                      Estado de mierda de encargo
                      • 6871
                      Searching would have found your answer. I can assure you. You wouldnt have even needed to make this thread.
                      • flawdaboi407
                        • Mar 2008
                        • 324
                        I can assure you I DONT GIVE A FUCK!
                        Anyways... The bumpers are used. I got them locally for $74.99!!! I took all the trim of sanded and painted them flat black. The chrome I just cleaned with some Hot Wheels for rims.
                        • scabzzzz
                          • 6871
                          You dont give a fuck? I guess thats why you got practically no response to shit you could have found on your fucking own. Noob.
                          "Fast replys please, its getting dark!"
                          Anything with the word euro bumper in the search bar would have brought up the thread with a huge write up I did on it which I spent good time doing for assholes such as yourself. Thank you come again..
                          • flawdaboi407
                            • Mar 2008
                            • 324
                            I had the day off today and deceided to install the rear. Here are some pics... enjoy!
                            p.s anyone have a rear valvance/skirt? or is there something from another car I can mod to fit?
                            edit* oh yea.. I smoked the tails a few weeks ago too, along with new rims/shoes. Front h&r 15mm spacers, rear h&r 20mm spacers, 15" MODA by bbs with falken 912's 205/50 (front) and 225/50 rear. Will post better pics later.
