What color to paint?
  • rs4pro3
    • 5808
    Ok I'm working on regasketing my whole 84 633csi engine and can't decide what type paint to use where.
    The block is clean and will be painted with some 1200F Black Engine Paint, the oi filter assembly will be painted the same.
    Now I can't decide weather I want to paint the Valve cover and intake manifold with the same paint, or Paint them with a glossier Black engine paint.
    Here is a picture of the two paints
    The Engine block and Valve cover have the glossy paint, and the Exhuast manifolds have the Black High temp Paint.
    I like the look of the Plain black over the glossy which is why I'm using it for the block. But I like the Contrast of the sanded raised sections with the glossy paint, and I'm unsure if the sanded raised sections will stand out as much with the darker paint.
    Plus the darker(hightemp) has a much smoother appearence to it when done so I'm leaning that way.
    any opinions?
    85 325e 2.7 ITB'd stroker
  • Skafrog
    • 1732
    you wont see the block when its in the car, who cares at that point, I doubt there will be much difference between gloss or semi gloss. However, the valve cover is a different story. Personally, I went for the look of the m50 cover when I sprayed my valve cover, so go with a semi gloss paint. I would definately not go for a glossy valve cover.
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
    • rs4pro3
      • 5808
      I guese the black is a semi gloss, I just can't decide between the two.
