Full respray, how much base coat and clear will i need?????
  • denisbmwm5
    • 347
    Hey guys, im going to finish masters tommarow and need to buy paint and clear for my 87 325is that i will be fully repainting. I painted before but never a whole car, so i need you know how much paint and clear will i need. I was thinking a gallon of paint but seams to mure i think. please let me know asap thanks
  • M-technik-3
    • 18946
    Talk to D///M, He's a body person.
    • Jordan
      • 12916
      you will need a touch under a full gallon of base coat to do a complete color change inside, out and everywhere in between. This allows for 2 coats.
      Figure at least that much clear, if not more.
      https://mtechniqueabs.com/
      • JamesD
        • Apr 2004
        • 54
        it really depends on the quality of the paint you buy. if you get a real high quality thats mixed 1 to 1, then you may only need 2 to 3 quarts, but if you buy cheaper paint that is mixed 2 to 1 you will probably need a gallon. you should ask the tech guy where you buy the paint how much you will need. if they don't know i wouldn't but it from them.
        • denisbmwm5
          • 347
          Yeah a figured around a gallon for base paint but i thot it would be like half a gallon for clear? im a right? also im not doing the door jems and shit like that, only the exterior because im repainted it same color.
          Jordan you know how much clear the body shop used for your car?
          • Jordan
            • 12916
            I had 2 coats of base, and 3 coats of clear.
            You will use more clear then base if you are doing it right...
            • denisbmwm5
              • 347
              How did the paint job come from the factory??? 2 coats base 3 coats clear?
              • Jordan
                • 12916
                um... i would venture a guess of 1 base coat, and 1 clear coat.
                • denisbmwm5
                  • 347
                  Damn thats good shit then if that paint stayed on my car for 16 years, 1 base ans 1 clear is fucking sick if thats it.
                  • Jordan
                    • 12916
                    Well it is all sprayed by machines in a clean room/pressurized chamber. I mean you just can't get results like that down at Maaco.
                    • 808BMW
                      • 2910
                      1base and 1 clear from the factory is going to last a hell of a lot longer than a respray with the same.
                      • Jordan
                        • 12916
                        Yeah, well not all paints are created equal. Price the difference between 1 gallon of PPG and 1 gallon of Glasurit.
                        Also the EPA is constantly breathing down the necks of those making paints. The paints we have today are no where near the potent goodness of yesteryears.
                        • NC325iC
                          • Mar 2004
                          • 6565
                          i have a quick question about paint
                          i took my car to my mechaninc a while back after he replaced my clutch and timing belt
                          i asked him if he could give me a ballpark estimate for spraying my es/is valence
                          he said since its so close to the ground i should use a urethane based paint instead of whatever is usually used
                          would this be better or is urethane base crap?
                          thanks
                          • Jordan
                            • 12916
                            Most widely used automotive paints are urethanes... my car is.
                            • Schneider325
                              • May 2004
                              • 3818
                              off topic but, my dad works at PPG and he is taking in my IS lip/side skirts/rear valence into work and painting them. He found the paint code and he's gonna order somem more matching paint. There going to to use my parts as experments and put some prouducts on it that arnt out in the market yet. free paint work, hehe, but im doing most of the sanding, its all go tho!
