what would it cost to get this fix... any guesses
  • natorious
    • 672
    the only spot on my car that has rust is a 1.5"x1.5" spot on rear valance under the bettery tray... has anyone gotten this area repaired... and what did it cost you.. im gonna try and find a pic in a minute.. if i cant find one i will post one tomorrow... my camera is at work
  • natorious
    • 672
    • bmwm3n528
      • 3654
      50-75...you talking about getting it done body color, or having them redo the black lowers?
      Trevor Ely
      '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
      '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
      • e30Matt
        • 5077
        Sheez... that's a cheap fix right there. Get a patch welded in there and do the paint yourself, you won't even touch three digits. :)
        • natorious
          • 672
          basically i just want the rust gone.. having them paint it probably wouldnt add much i dont think so i might as well have em do it
          • Jon '92 325ic
            • 172
            I've got the same thing
            I've got the same thing, except on the corner. Even the amount of rust. If you want to do it yourself, POR-15 has products that will do the trick. I just went and got an estimate from a highly recommended body shop that specialized in BMWs and they quoted me $250. I'm going to get another quote this weekend probably.
            But check it out if you want to take a stab at it yourself:
            Explore POR-15's extensive range of metal protection and restoration products, perfect for bringing new life to any vehicle, heavy-duty machines, or outdoor metal asset with superior corrosion resistance performance and quality. Order online now!
            • iXer
              • 242
              A good sand blasting, then clean with a good solvent and slap some nice etch primer on there, a layer of urethane and then some black body.
              If you've got the tools, that's an hours worth of work.
              /Mattias
