installing IS side skirts
  • OSM e30
    • Jan 2007
    • 55
    im just wondering how i install the clips on to my car so i can put my IS skirts on, my car didnt have the original clips to install it, i got all new hardware. so im just wondering if anyone can help me or show me a picture of how they installed theirs on
    thanks
  • E30_fiend
    • Apr 2006
    • 7348
    You have to drill holes for the clips in the rockers. I'll see if I can find the article with a template
    • Van Westervelt
      • 9365
      I have been lazy, I need to install mine too.
      • OSM e30
        • Jan 2007
        • 55
        yah i just gotta paint mine then put them babys on
        • brandon11130
          • Jan 2008
          • 635
          There is a lot of holes, when i took mine off I was supprised there were so many. I would be weary to install a set on a car that wasnt equiped with them from the factory.
          If you do it, make sure you absoloutly paint all the bare metal in the holes, or you will have a nasty supprise when you remove the skirts.
          • Eric Giles
            • 1068
            Please do, as I have brand new set I bought from the dealer that just got painted and I need to install them. A template and article would be of much help.
            Thanks!
            Eric Giles
            '20 M2 CS
            '04 M3
            '11 X5 35D
            '87 325is
            '91 325i Sport
            There are few things more expensive than a cheap BMW...
            • monty
              • Feb 2007
              • 665
              I just installed mine. They have been painted for almost a year now. I was just being lazy aslo. Plus I was hesitant to drill holes into the car (even though I work at a body shop).
              • e30serg
                • Dec 2006
                • 562
                Me four? I have a set, haven't made time to install them. Does anyone have a template?? What size drill did you use monty??
                • Nicademus
                  • 2912
                  Me 5, I have Hartge side skirts and I really don't want to drill holes in my car.
                  Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
                  ~ John Adams ~
                  • Kilawin
                    • Dec 2005
                    • 994
                    3M double stick tape is your friend.
                    • Nicademus
                      • 2912
                      What, like secure both ends and then a bunch of tape down the middle?
                      ~ John Adams ~
                      • Kilawin
                        • Dec 2005
                        • 994
                        I used 3m tape on the top section where rivet mounts should be and used the factory mouting clips for the bottom. No problems
                        • Eric Giles
                          • 1068
                          Not a bad idea, and something I was thinking of doing also. How long as it been since you did this? I am somewhat concerned of the longevity of the adhesive and possibly losing a sideskirt one day.
                          Eric Giles
                          '20 M2 CS
                          '04 M3
                          '11 X5 35D
                          '87 325is
                          '91 325i Sport
                          • Van Westervelt
                            • 9365
                            DO NOT put them on with adhesive only. You will lose one that way. Use at least half the mounting points. And thats still lazy.
                            • Eric Giles
                              • 1068
                              That was my plan-use the locking clamps on the bottom of the rockers, and then adhesive along the upper portion. IF I had the instructions and the template, I would most certainly go that route-but if I can't get those, I would rather not drill holes with only a 'guesstimate' to go by.
                              E30_fiend...you found those instructions and template yet?
                              Eric Giles
                              '20 M2 CS
                              '04 M3
                              '11 X5 35D
                              '87 325is
                              '91 325i Sport
