After poking around here and reading quite a few threads on the matter, I set forth to install my Momo wheel and hub in place of the nasty OE airbag wheel I got with the car. I was able to hunt down the non airbag spacer at the junk yard (I got three to be safe) and put one before the hub as well as one after the hub and it feels nice and solid, but the hub doesn't cancel the signals and the horn doesn't work. Before I got the spacers, I had some washers stacked up in their place and the turn signal cancel and horn worked fine, but the wheel was way too close to the stalks and the wheel felt kind of wobbly.
Now the wheel feels nice and solid, but I have the non functioning horn and turn signal cancel. As it is currently installed, there is a gap of about 6mm between the back edge of the hub and the plastic column trip pieces where the stock wheel used to sit against. Is this normal? Also, when I push the steering wheel in (as you would push the hub on to the splines), there seems to be a little bit of give, though everything seems to be on nice and tight. I know there is a spring back there, but just want to make sure it's supposed to be this way. Is this normal too?
Thanks in advance.
Thanks in advance.
