signal light rellay
  • E30_(1st Musk)_
    • 2008
    signal light rellay
    is there anyway that i can get to the rellay without having to remove the steering wheel?? i cant find the rellay. so i cant replace it..help guys
  • John in VA
    • Aug 2007
    • 553
    If you have a stock steering wheel, it's no big deal to remove. 22mm socket for the nut under the horn button. You might need to have the key turned to the first position to pull the wheel off, depending on the production date of your car. Make sure your wheels are pointed straight ahead when you pull it so you get it on straight when you're done!
    It's been a while since I replaced my turn signal, but the screws are under the shroud, holding the two halves together. See how far apart you can get it w/out removing the wheel, if it's a problem.
    • E30_(1st Musk)_
      • 2008
      well the thing is that everything on this car but the radiator hasnt been touched.. and so all the plastics n stuff are nice. so ide hate to be the first to break something. so i canted to double check.. another question.. can i use a multi purpose. because i didnt find a signal light relay?
      • John in VA
        • Aug 2007
        • 553
        Use the correct tools and you won't break anything. And get the correct parts - it'll simplify your life. If you have no skills or tools, take it to someone who can do the work properly.
