What product to deep clean leather?
  • funcrew
    • Jun 2007
    • 1223
    While I was at work today, Mrs. Funcrew went after the old OEM leather on my sport interior with grade 0000 steel wool and some purple power cleaner. That definitely took off a layer of grime, but I'd like to get a little more aggressive with the cleaning before I apply rejuvinator oil and steam that in. I've seen a mix of acetone & other solvents recommended, but I'm hesitant to get that crazy. What would you use to clean the leather thoroughly with steel wool?
    Discuss.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • td325ic
    • Feb 2006
    • 786
    If you're just trying to remove grim then a Mr. Clean Magic Eraser works very well on leather and amazing on vinyl. Much better than steel wool or scrotch brite pad surprisingly.
    The leatherique rejuvinator oil will bring the deep embedded grim to the surface, so you actually don't need to get the seat super clean before putting on the rejuvinator oil for the first time. Let the oil dry and then wipe off the grim from the surface.
    So really for simple cleaning just leatherique's rejuvinator oil and pristine clean work well. For things you can buy locally, Meguir's Gold Class Leather Cleaner & Conditioner and Blue Magic Leather & Vinyl Cleaner both do a good job on cleaning the leather without hurting the finish. Just apply the product, give it a few moments before scrubbing it off with a terry cloth.
    There are further steps I could recommend which will actually get the leather noticeably soft again but unless you're willing to do some dye work as well then it's not worth going that far.
    • maco325e
      • May 2007
      • 177
      I remember a few years back I used Mr. Clean Magic Eraser on my rear seat and took the dye off the leather, so if you are gonna try it, start working on a small area just in case the same hapens to you.
      • aworthybrother
        • May 2007
        • 899
        I just used the Mr. Clean Magic Eraser on all my vinyl seats and door cards. It cleaned my interior well.
        • StereoInstaller1
          GAS
          • 22679
          Magic Erasers are a chlorine bleach based product.
          Personally, I would never let chlorine touch my leather.
          I use acetone when prepping the leather for paint. Didn't remove any color, but certainly got 100% of the "sheen" off.
          GL and post your results!
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
          • NC325iC
            • Mar 2004
            • 6565
            magic erasers do not use bleach they clean like a very fine sand paper
            • StereoInstaller1
              GAS
              • 22679
              http://en.wikipedia.org/wiki/Magic_Eraser
              Wow, Weird. To me it smells like bleach and it makes white nylon turn yellow, so I suppose that is why I thought it had chlorine.
              That article is interesting though.
              I wonder of they add anything to it?
              Closing SOON!
              • funcrew
                • Jun 2007
                • 1223
                Thanks to all - will clean again with acetone and 0000 steel wool. I will be using the Obenauf (butchering the spelling there) fine leather oil & steaming it in per the Leatherique instructions, followed by final cleaning with Leatherique "pristine clean" from my shelf of random leftover stuff. Will report back with results.
                -Dr. Paul Forrester
                • 91E30-318is
                  • Apr 2009
                  • 34
                  I'm going to dye my seats soon. So how do get the leather soft again?
                  • John in VA
                    • Aug 2007
                    • 553
                    Use the method detailed in the thread - Rejuvenator Oil followed by Prestine Clean. That way the leather will be nice & clean, as well as softened before dyeing.
                    Here's a link to doing it correctly:
                    Learn how to properly use one of the best leather care combos on the market, Leatherique Rejuvenator Oil and Leatherique Prestine Clean. These two products can restore hardened, faded and neglected leather. See how Todd uses Leatherique with step-by-step instructions and pictures.
                    • robspeed325i
                      • 403
                      i saw leatherique work in person at a clinic last winter up at reggie's... if i hadnt seen it with my own eyes i would never have believed it! stiff brittle leather turned to absolute butter soft wonderful!
                      Reggie’s Motorworks in Noblesville, IN specializes in all German import repairs and maintenance, including BMW, Porsche, Audi, Volkswagen, & Mercedes-Benz.
                      • naplesE30
                        • Nov 2007
                        • 1840
                        Hey I am getting ready to do my seats, but I wanted to bounce this idea off you guys.
                        My seats are really cracked and dry. I was thinking of wet sanding the dye off my seats before using the rejuvinator to get better absorption. Has anyone gone this route?
                        • ck_taft325is
                          • Sep 2007
                          • 6880
                          ^ No.
                          Need a part? PM me.
                          • TheB1G Lebowski
                            • 593
                            Yeah i need some help with this too. I just got some cardinal red door cards and interior pieces the only problem is they are faded a bit darker than original. I got some Armorall leather conditioner and it worked well to bring some life back to the leather but it still is very dark. has any one had experience bring the color back to life in older panels? Thanks.
                            1989 325i - sold
                            1987 RX-7 Turbo II - sold
                            1990 325i
                            • Mless5
                              • Jul 2006
                              • 817
                              = dirty.
                              Woolite mixed with water 10:1.
                              '96 328is
                              '97 m3
                              '04 zhp
