black headliner piece
  • Fingprep
    • Nov 2008
    • 27
    Hey can some one tell me how to take the black headliner piece off with out breaking or bending it?
  • Jean
    • 18228
    The one near the front windshield, above the sun visors? It's tucked under the left/right door seals and sunroof part...
    • Fingprep
      • Nov 2008
      • 27
      That's the one. Do you have to take the sunroof out to remove it? Is there any clips I should worry about breaking?
      • Jean
        • 18228
        Just slide it back, you'll just need to remove 6-10 small phillips screws. Remove the sunvisors and brackets, and pull the top sections of front door seals down. And sunroof crank if it's manual.
        • Fingprep
          • Nov 2008
          • 27
          How do you get to the screws that are holding the back of the headliner piece? I have the sunroof open and can see the screws but can't get to them my off set screw driver is too long. Are you suposed to take the wind deflector off? If so how do you get that off?
          • Van Westervelt
            • 9365
            Yes, you have to take the wind deflector off. It unscrews all along on the underside after you snap each side out of its lifter arm.
            • Fingprep
              • Nov 2008
              • 27
              How do you get the lifter arms off?
              • Fingprep
                • Nov 2008
                • 27
                never mind
