Gauges...
  • HSPD-561
    • 64
    Gauges...
    Got a set of white-face gauges to replace the yellow ones in my car. The gauges I got did not come with instructions to put them on. Anything I should know to make the job easier? Thanks in advance for any help!!!
    "Drive it like you stole it!!!"
    "Its only illegal if you get caught!!!"
  • Desaevious
    • Aug 2007
    • 3810
    I've never replaced the faces them selves but to get the plastic covering off the cluster you can gently pry it off. Then to get the needles off you should be extremely careful. Lift them off by using the "fork method" for equal pressure that will pop them off without bending them. As far as the faces would you I'm not sure what adhesive you would use to mount them, unless they were ready with sticky backs. But as long as you know once you do that, you won't be able to get your black gauges back without buying new faces or getting a used cluster and swapping.
    Good luck.
    SC*AR (Schwarz Army)
