Best way to attack steering wheel removal?
  • HarryPotter
    • Jan 2010
    • 3642
    Sold my tech 2 wheel need to get it off the car, not exactly sure what the best method of attack for this is. I don't want to damage the wheel at all. Especially removing the roundel in the middle without scratching it or anything.
    Thanks.
    John F. Kennedy
  • browntown
    • Jun 2004
    • 3524
    I don't know how the tech II wheel goes on, but every other one I've seen requires peeling the roundel off and then hitting the nut with a socket. Dental pick and some niceness should get the center up without gouging anything.
    Again, I don't know the tech II wheel's internal design though.
    • HarryPotter
      • Jan 2010
      • 3642
      I believe it's the same as any other oem e30 wheel. But this is good advice with the dental pick.
      John F. Kennedy
      • Wh33lhop
        • 11705
        I've never had any trouble with a flathead on either of my wheels--pry at the top of the roundel, it should pop out eventually. You'll need a 22mm socket for the center nut, a deep socket never hurts.
        paint sucks
        • ck_taft325is
          • Sep 2007
          • 6880
          Just pull the center piece (not roundel, the entire center piece) off and undo the 19mm (?) bolt. Have the steering column locked but don't just torque the bolt off against the steering column lock, hold with one hand and remove bolt with a socket wrench with the other.
          Be sure to send the little spacers behind the wheel (and in front if you have 2) and send 'em off with it ;)
          Need a part? PM me.
          • booostit
            • Jul 2009
            • 224
            what about cars with airbags? just curious how you are suppose to get them off. besides taking the relay/fuse and disconnecting the battery how do you proceed next?
            • Gooch
              • Dec 2006
              • 1674
              Nailed it. On the M-tech II you don't need to take off the roundel, the entire horn pad comes off, revealing the nut holding on the wheel.
              '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
              '87 535i - Vacuum brake conversion [SOLD]
              '93 525iT - 5-speed swap - 320k and counting
              '09 328xi - 6-speed
              • HarryPotter
                • Jan 2010
                • 3642
                lol just figured this out after popping the roundel off and then being like wtf? no biggie though. I've got it from here guys thank you very much. Kinda disappointed I have to throw this shitty half wrapped 3 spoke sport wheel on now after having the tech two between my gritty little palms for over a year.
                John F. Kennedy
                • mightywhitey
                  • Oct 2009
                  • 985
                  there are some screws behind the airbag wheels. 4 I believe.
                  1991 e30 328i M52 swapped: Gone
                  1995 e34 540i/6 1 of 76 Clean
                  1985 e28 euro 525i the daily
                  • T Verdier
                    • Aug 2007
                    • 2636
                    So your slowly down grading your car to stock?
                    • HarryPotter
                      • Jan 2010
                      • 3642
                      lol, nahhh. I'll be picking up a momo or something.
                      How n the hell did you guys get the wheel off? 3 jaw?
                      John F. Kennedy
                      • chadthestampede
                        • Jul 2008
                        • 3601
                        Just pull it off. Make sure the key is turned so you can spin the wheel or you'll break something.
                        Originally posted by LJ851
                        Feedback
                        • HarryPotter
                          • Jan 2010
                          • 3642
                          oo alright had the key in the locked position. For fuck sakes, you turn the key it slides right off. I am a ruh-tard.
                          Now though, the two spacers am I gunna need those? Or will the old wheel just go on without those? Cause if I need em I can't send em out with the wheel.
                          John F. Kennedy
                          • george graves
                            • 20003
                            This was painful to read.
                            Originally posted by Matt-B
                            • HarryPotter
                              • Jan 2010
                              • 3642
                              Any info on the spacers/washers?
                              John F. Kennedy
