Original problem is here: http://r3vlimited.com/board/showthread.php?t=160647
Well I decided I didn't want to plug up the upper drain hole as a bandaid fix so I took out my dremel took and cut two openings to do some further investigation
I did some more water testing and it looked like water was getting into the visible seam. So I went to my friend bodyshop and borrowed some sealant
I didn't take any before pics but you get the idea of where the seam is
I did a water test and water was still getting in so that didn't work.
After doing more water testing there was only one spot left that I could think of and that was this inside seam that is very hard to see which I thought was part of the fender.
I did an isolation test with my blue water and it went into the cabin! Did a retest with red water and confirmed this was the spot.
So waiting for the spot to dry and sealing it up.
