How to removel plastic trim around CD player and hazrad? help needed
some one correct me if im wrong but you have to remove the trim peice under the cluster theres 2 thumb screws under the dash. then theres a screw hidden under that pannel for the pannel you need to remove then there are 2 screws under neither one on either side. hope that helps
The HVAC panel? Don't need to remove the cover under the cluster.
Remove the analog clock or obc, push the hazard/defrost switches out. You'll then be able to get to the top two small phillips screws. The other 2 are on the bottom above the ashtray.
