sun visor panel coming unglued
  • madformx5
    • 817
    The panel that holds my sun visors has material that has delaminated. I was wondering what you guys have done to fix this problem. I looked on realoem and that panel has been discontinued so I have to either find a good on or fix the one I have. The damn Texas sun is so hard on interior parts.
  • Jand3rson
    • 37587
    There's not really a way to fix it other than stripping off the old vinyl and having it re-wrapped, or re-wrapping it yourself. Mine was doing the same thing, and I just searched around until I found a perfect one, and swapped it in.
    • madformx5
      • 817
      Cool, thanks J.
      • IRON-E
        • 16548
        I tried shooting glue with a seringe and then spreading the glue once inside and leaving it in the sun so that the vinyl would soften but it only made it worse cause the other areas started to come loose with the heat too., maybe the best solution is to re-wrap it or buy a used one in better condition then your existing one as previously stated.
        @IRON-E30 aka Edwin:D
        • glucklich21
          • 1912
          I just finished recovering mine in suede and dying the visors and mounts black to match. Well match better than grey.
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            i have beem saying for years, someone should make a carbon fiber one, along with a knee bolister because they also often break
