Glovebox latch broke
  • blefevre
    • Dec 2008
    • 4287
    Yep, the thing broke. I searched and there is a DIY repair that the link no longer works.
    The handle part just fell off leaving me with a metal "hook". I assume this is the catch that people speak of? Well anways, I tried to pull on that only to break that thing. My question is which way is that supposed to move? To the right, left, out, in? If it is the right/left I might luck out and be able to shove a screw driver to push it. If not, what should I do?
    Thanks! - My hartge caps are stuck in there :(
    - E30, DSM, Golf R, Mazda 3 Skyactiv
  • jeffw
    • 1087
    the hook goes to the right (passenger side) and you shouldn't need a screwdriver my buddys is like that and its doable by hand
    • blefevre
      • Dec 2008
      • 4287
      Thanks!
      I need the screw driver because I broke the clip already There is just a small stub left of it.
      • jeffw
        • 1087
        ahhh gotcha. thats shitty. Go to the junkyard and find a complete new latch they are cake to replace.
        • caliGreen
          • 195
          yup i replaced mine like 4 times... latch keeps on breaking or it wont open.. i just pull the damm thing out like the hulk and pick one up an junkyard for 10
          • xwill112x
            • Jan 2009
            • 4236
            i usually just replace the whole glovebox as it gets thrown out of a moving e30 at 70+ mph. lolz
            • blefevre
              • Dec 2008
              • 4287
              So here is an update. I coudln't flip the catch so now I started destroying it.
              Question: Is the part I am hacking away at part of the glovebox or am I messing up the mount for it? I want to put a new one in after I beat this one up, but I think I am messing up the mounts.
              Advice?
              • xwill112x
                • Jan 2009
                • 4236
                Advice?
                you now see where my above post comes into play! :-D
                • blefevre
                  • Dec 2008
                  • 4287
                  So I am only damaging the glovebox? It will make good target practice!
                  • blefevre
                    • Dec 2008
                    • 4287
                    Not having much luck. Is there a trick to this? Am i supposed to pry out the entire thing or just some pieces of it? I could drill but I am nervous because I don't know whats behind it.
                    • Cyrano
                      • 163
                      had the same prblem. just put in a screw driver and break the black plastic piece... if u cant open it with the latch. after u break it u will not be able to close he glove box so make sure u have the new lock in hand... from then u can just exchange the lock internals from ur handle into the new one, then just screw it back on....
                      • caliGreen
                        • 195
                        what i did was unscrew the 3 screws in the back so i can get loose then messed it up and pulled it out
                        • blefevre
                          • Dec 2008
                          • 4287
                          I got it out. I just had to use more anger
