Fix a worn out/shinny steering wheel.
  • george graves
    • 20003
    I saw this on another forum - thought I'd share.
    1) Assemble Your Kit + Notes Below is the total kit I used. As you can see, there aren't many tools required for this job at all. This cleaner is called AquaPur, however there are many, many different brands available in the shops. In USA the most common one is called Magic Eraser.
    Ensure it looks like this, i.e. the bottom is white and the top part of the sponge is a different colour and also different material.
    The steering wheel usually becomes shiny due to grease, oil and dirt from your hands after years of use. This cleaner works as a very light abrasive and removes the oily / greasy coating off the steering wheel.
    Some believe that this process damages the leather finishing, but that is not true (provided it is not done too often) - my steering is now as good as new!
    2) How to Use the Cleaner Dip the sponge in a bowl of cold water and wring out all the water.
    Softly rub the steering wheel a few times back and forth with the white (soft) side of the sponge. You will normally find the instructions on the box, which will tell you which side to use.
    Next dry the water on the steering with the cloth and check if you have cleaned it enough.
    NOTE: Do no over do it whilst rubbing / rub too hard, as you may ruin / destroy the finish of the leather.
    Below you can see the difference it makes after cleaning it.
    3) Half Cleaned Steering Wheel Half of the Steering Wheel cleaned. I am sure you can guess the old shiny side?
    When the sponge gets / looks dirty, clean it in the bowl of water.
    4) Dirty Water As you can see, the water is filthy. All that came of my shiny Steering Wheel. 5) Fully Cleaned Steering Wheel This is the end result of cleaning the Steering Wheel.
    6) Extra Tasks Once your done and confident with the steering wheel finish, proceed with the leather on the doors and the dash board. Remember to rub lighter on these 2 than you did on the Steering Wheel as they are not that dirty / greasy.
    Also, remember the Gear and Handbrake and the leather cloth attached to both of them, also the middle Arm Rest.
    It is not advisable to use this on plastics or any other part of the car, e.g. leather seats.
    Originally posted by Matt-B
  • SeriousBusiness
    • 428
    Wow this looks really good. Our old dry rotted E30 wheels though are probably beyond saving, apart from re-upholstery.
    1985 RX7 - Badassery Exemplified.
    1989 325is
    -Tom
