How to install a dead pedal?
  • Jand3rson
    • 37587
    I'm going to install my new pedals this weekend, but I'm unsure about how to mount the dead pedal. Can I just go with self-tapping screws directly into the floorboard? What is under the carpet?
  • Sean
    • 5793
    Re: How to install a dead pedal?
    There's a lot of padding under the so called "dead-pedal". The metal, I think, is a good 2-3 inches down.
    - Sean Hayes
    • Jand3rson
      • 37587
      Anyone have anymore info on this? I don't want to fuck anything up here.
      • e304lyfe
        • 807
        sean is right... there is a considerable amount of foam underneath the dead pedal.
        u'll be fine, screw it in, no worries....
        • nickmp0wer
          • 1427
          what you should do it put a block of wood in there too for a spacer cuz at least i think the dead pedal is too far away
          • DEV0 E30
            • Oct 2004
            • 8896
            I'm short too.
            • nickmp0wer
              • 1427
              im 6 feet tall
              • Jand3rson
                • 37587
                That's actually a good idea, maybe I'll pull the carpet and padding up in that spot, see what's what, and make some kind of a solid spacer to go in there.
                • boom-monkey
                  • 1104
                  im 6 feet tall
                  Move your seat forward. Your ridin' Mexican style. Your should be able to rest your foot on the dead pedal to be able to operated the other pedals correctly.
                  • jht3
                    • 288
                    also, w/ your foot on the dead pedal you should have a bend in your knee. this way, if you're in a collision your knee can absorb the forces and not blow your hip out. this will bring your arms into a bend as well, resulting in better control of the wheel
                    i'm 6'2" and i keep my seat 1/2 way, if not a bit closer. felt weird at first, but i've gotten used to it. on long stretches i do tilt my seat back instead of the upright position if i'm truly driving
                    James
                    '88 M3
                    • Bimmerfanatik
                      • May 2004
                      • 5349
                      I'll place bets 9 people out of ten on this board don't sit right. Why? Because sitting right feels uncomfortable until you sit in it long enough. Everything you said above is completely right...posture in the driver's seat is extremely important in reducing injuries in a crash.
                      If you're comfortable behind the wheel, unless you've been doing it right for a while, chances are it's not right. That seatback should be almost completely upright, your knees should be bent, and you should be able to rest your wrist on the top of the steering wheel while keeping your back and ass against the seatback. Could save your leg or arm or better...
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        ^^ That's how I sit. Looks kinda goofy, but it ensures that the bolsters are in complete contact with your torso at all times.
                        Originally posted by Gruelius
                        • Jand3rson
                          • 37587
                          I'm with you guys, I sit fairly close and upright, you feel more in control that way, and my foot rests just fine on the dead pedal, with a bend at the knee.
                          In the last few weeks though, I've had to move my seat back, because I've been having a bad pain in my left knee, and if the seat is close, it hurts really bad to move from the dead pedal to clutch, and to put the clutch in and out.
                          • Bimmerfanatik
                            • May 2004
                            • 5349
                            Bingo. Though some with wider backs are SOL....I'm 5'7 and 175 lbs, so that aint me. I'm no cock diesel mutha fuckah.
                            • Bimmerfanatik
                              • May 2004
                              • 5349
                              That sounds serious.... I've heard of these symptoms before. It's called waffleswaffleswaffleswaffleswafflescantdrivemanualitis. Better kiss you driving days goodbye, you're losing that leg.
