Airbag to Aftermarket
  • BigTe30
    • 207
    How painfull is the swap from an airbag steering wheel to an after market one. I've also heard bad things about aftermarket steering wheels (misc. issues with things on the column). Bascially is it worth the hassle, thanks in advance.
  • jasonsnoddy
    • 1900
    its no deal at all. you make it sound like a big deal. i went from airbag to m-tech in about ten minutes, i love it.
    Originally posted by stewie30luvr
    ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
    Originally posted by JakeP
    with a coathanger
    • trackjunkie21
      • Jan 2010
      • 3962
      word, same here. as long as you can live with the srs light on then you're good, but their is a way around the light.
      Originally posted by Wh33lhop
      VANOS: sometimes you just need to go full retard.
      • 17sd
        • 158
        I changed my overhead panel to a non-SRS one.
        You will also need a spacer.
        Other than that it's quite straight forward.
        • BigTe30
          • 207
          Thanks for the advice
          • g.ruff561
            • 1268
            I tried this swap with a oem sport 3 spoke wheel. I love the look, but I have no horn. I used the xtra spacer and I am happy with the results. Just no horn. Any suggestions??? Thanks in advance for your advice.
