I know a few guys have redone or reglued their hardtop rooflining. I've reglued mine once before with the 3m spray stuff. Now its sagging again so I'm taking this opportunity to redo it in a different material. Anyone do theirs in vinyl or leather? and also include pics thanks.
hardtop roof lining options
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None -
I am thinking of doing mine in the vinyl they use for covering the hood, roof etc. Easy to maintain and will not have to worry about sagging. The vinyl should be easy to work under the rubber with out messing it up. Do you know whats under the cloth? I will have to clean surface before applying. I will be having ZMBLUEDEVIL do mine. -
^you do know that the vinyl in coupes are held by wire supportsRenting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Yeah I meant hardtop on cabrio. Theres nothing but glue holding up the cloth headliner to the hardtop...so if you were to do vinyle you still have the chance of it sagging so I dont see what point your trying to make.
My question was what other materials have other ppl used to redo their hardtops.Renting my rear wheel bearing tool kit. SIR
no not the vinyl/leatherette. I am talking about vinyl car wrap. Here is a thread. http://www.r3vlimited.com/board/showthread.php?t=135600&highlight=vinyl+hood.
This should not sag at all.Comment
The upholstery shop I go to uses a different formula of spray glue but they tell me it will eventually break down over time and start to sag.
We have a spare hardtop and plan to strip it down, seal up the inside and outside surfaces and have it painted to match the car.
My 1989 e30 s52 Touring... this is Betty
My 1989 325i vert (sold)...this is Nina
My 1991 M5 (sold)... this is Veronica
Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
Cabrio Hardtop liner replacement
I've seen a few threads on this topic in this and the Paint & Body, Interior and E30 FAQ DIY forums. Try search in those. I plan to replace mine as well so am looking for OEM or a reproduction. Will repost here if I find a source for one. The first one lasted at least 15 years, so if I can get the substrate right then that seems to me to be the way to go.
Matt
McLean, VAComment
