How do you fix a broken sunroof crank?
  • ac3
    • Jan 2011
    • 121
    My jackass friend yanked it off. Completely sheared the metal piece in half. What parts do I need to look for? The bentley manual has nothing on the crank.
    Thanks
  • e30shmobberr
    • 1934
    junkyard.
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • Gadea
      • 454
      not too hard to find one. At least one that works, unlike the one you have. Hope your sunroof was closed when that happened.
      1998 528i auto on staggered DSII
      • ac3
        • Jan 2011
        • 121
        It was open, ended up clamping a power drill to the broken shaft to wind it closed... Worked like a charm! After looking at how to remove the broken piece of the crank it looks pretty easy to replace. Hopefully I can just screw the new one in.
        • accident
          • 7303
          the white piece with the two screws in it is what normally holds the crank. take out the two screws and replace the whole crank assembly. i got one from here for $15.
          Moral of this story?
