European Gauge cluster
  • Schneider325
    • May 2004
    • 3818
    I did a search and couldnt find anything. What models will this fit on? I want to keep this baby, but if it wont fit my eta then i'll put it on ebay.
    Thanks
    Jon
  • ColdAccord
    • 5926
    it'll technically fit anything, man. speedo looks off though, eh? the needle is supposed to be down a bit.
    I've got one, came in my car. Had to swap out the speedo for a MPH one though
    Originally posted by blunt
    • Schneider325
      • May 2004
      • 3818
      Well which models are "plug n play" then.
      • jht3
        • 288
        motometer and vdo do not swap
        if you started vdo, then this vdo might work w/ some wiring tricks
        James
        '88 M3
        • arsevader
          • May 2005
          • 1025
          As long as the cluster is from the same type of car you should be fine even between VDO and Motometer. You can even swap the gauges from one type to the other with some fiddling.
          James
          • Court M3
            • Jan 2004
            • 6713
            Schneider, I got an early model one that will fit the eta. PM me if interested.
            Continuous For Sale Thread
            323i s50
