89 325i coupe steering wheel removal HELP!
  • frickendom
    • 382
    I have a 89 coupe with the 4 spoke steering wheel. I am trying to remove it but it doesnt come out. I removed the emblem then I used a 22mm socket to remove it, but it does not budge. Any help? I already used a lot of elbow grease. Maybe not enough?
  • Van Westervelt
    • 9365
    Put your key in the ignition and turn it to on. Your steering wheel is locked in position right now, that keeps it from coming off.
    • frickendom
      • 382
      Its not that, I cant get the nut off.
      • jaywood
        • Jul 2010
        • 4528
        Did you get the nut off?
        • Ceeker
          • Sep 2009
          • 2821
          ok, in the morning have your wheaties!!! wait a bit, get your 22mm 6 point socket and 1/2 inch drive. keep the steering locked and then put your back into it young man..!!!!! LOL then put the key in to release it from the hub. Keep the nut on and wiggle the wheel side to side until you feel it freeing up. if you decide to yank on it while the nut is off you might give yourself an upper cut and knock yourself out. So I recommend you pull on the wheel while the nut is in place.
          Don't tell me you stripped the nylock? that's almost impossible!!!
          • jaywood
            • Jul 2010
            • 4528
            When you take the nut off hold the steering wheel with the other hand and pull/push so that the steering lock isn't the only thing keeping the wheel from spinning.
            • frickendom
              • 382
              got it! thanks guys.
