Redoing seats...
  • Sean
    • 5793
    Redoing seats...
    Ok...so here's the thing.
    Both my seats wobble a little bit - front and back. my driver's side moves around more than my passeneger side.
    At one point, I had taken my seats somewhere to have them checked out. She took them apart, then put them back together - after deciding the leather was too dry to work with.
    They were tight before, now they're loose. Does this mean there may be some bolts in there that're loose?
    basically - here's what's up with the driver's seat:
    The back wiggles a little - however - it's stable when sat in (when I'm putting weight on the back, it's solid). HOWEVER, the seat bottom moves like 3-4 mm every time I lean forward to hit the brakes hard. So - anyone know what screws are loose - or what's up that would cause this?
    ALSO - while I have these bitches apart - would it be smart - or even possible - to replace the shocks in my seats? Is there anywhere to buy these without paying out my ass at the dealer?
    Suggestions welcome! :D
    THANKS
    -Sean
    - Sean Hayes
  • Nathan
    • Apr 2004
    • 671
    You have to pay out your ass for the shocks even if you don't get them from the dealer. If you move your seat often you should propably do it, but there really isn't a way to do it cheap, as far as I know.
    Just make sure every single bolt is tight and you should be fine. BTW are they Sport Seats or Non-Sport Seats?
    PNW E30 CREW ///
    • Sean
      • 5793
      Sport seats.
      I don't move them often, so screw paying for shocks. lol
      - Sean Hayes
