momo wheel hub/whee problem
    hey so i got my friends momo wheel/hub off of his early model vert, but when we went to put it on my late model it didn't want to go on.
    we couldn't get the steering to lock with the wheel on, also horn now wont work(both of which were not problems on friends vert).
    does it matter that my car is a late model?
    does it matter that my car came factory with an airbag?
    any help would be awesome.
    ...and no i wont sell it to you! :)
    I think you should it give it back to the original owner seems he had it figured out...
    My Multi car part out. Need a part? Pm me...
    http://www.r3vlimited.com/board/showthread.php?t=193051
    Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
    http://www.r3vlimited.com/board/showthread.php?t=215044
    Have you done business with me? If so leave me feedback here...
    http://www.r3vlimited.com/board/showthread.php?t=188307
      Lol, please do and make sure you turn the key, to the on position to get the wheel hub out of place.....
      @IRON-E30 aka Edwin:D
        number one, ill4noreason IS the PO! lol. and he was there, along with ubernasty, and the threee of us were scratching our heads.
        if anyone has any real help, then throw it out there por favor
          Oh, don't trip, I figured that much. I was just razzing you man.
            funny thing is it did lock in place, then tightened down, then it would not lock in place again. lol
              if it had a slip ring like oem wheels than you can take that out and it will fit but you will lose the horn, and return signal. that's how i did it with a mtech 1 wheel on airbag model.
                I think you need a spacer to install an aftermarket wheel into an airbag car.
                You can get it from the dealership.
                At least that's how I installed mine.
                  I had an mtech1 wheel and that needed a spacer. Weird thing is if I push the wheel in, with some force, it locks.
                  Also it wot cancel turn signals and I have to press in on wheel to unlock it or get horn working
                    hmmm my 87 has no airbag so it just bolted right up and i used a paper clip to ground the horn
                    once u bolt the 22mm (i think) bolt down and put in your 6 little screws i went driving mine
                    m20 is plenty. im simply a drifter.
                    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                      You need a spacer. You can get one made to go there. I'm not sure of the part number though. RealOEM is your friend.
                      S54B32 swap in progress. Status: Getting There
                        got it to work, had to un-do the bolt, and give it some wiggle room, push it in, i mean actually push hard on it, then as holding it in re-tighten bolt.
                        horn and turn signal cancle fine along with wheel lock. yay
