SRS wheel SUCKS.....Want to swap in my M-Tech I I have.???
  • wastedincome
    • Aug 2004
    • 906
    I've search enought to know that you can swap out tthe SRS wheel for aftermarkets, momo, etc. What do I need to do to sawp in a M-tech I I have?? Add a couple washers?? What is different bout rmoving the SRS wheel from others? I have never pulled a Air Bag wheel before :oops:
    Wastedincome420@yahoo.com
    CURRENT STOCK LIST:
    00' e38 750iL HighLine=Highway Queen
    92' e30 318 vert=Aint going anywhere
    91' e34 535iM=Aint going anywhere
    91' e34 525iA=For parts
    92' e34 535iA=For parts
    • 37833
    You'll need to make a 1 inch or so spacer out of washers or a piece of pipe and slide that on before you slide on your MTech 1 wheel. Then just tighten the wheel down with the nut and wham, done.
    Grover Beach, California
    BimmerHeads.com
    • wastedincome
      • Aug 2004
      • 906
      Ok, sounds good
      now how bout removal of the air bag wheel?? what do I need to do? I dont want a airbag blowing up in my face :roll:
      CURRENT STOCK LIST:
        • 37833
        Hmm, there should be a writeup on R3V somewhere, just not sure where
        BimmerHeads.com
        • Nick325is
          • 1409
          As far as removing the air bag first disconnect the battery and wait 30 minutes then reach under the steering column and there will be a small rectangular plastic cover. Remove the cover and there will be a small harness. Unplug the harness and then the airbag is disarmed.
          There are two torx screws on the back of the steering wheel that hold it on.
          Nick
          -who takes no responsiblity if your airbag blows up.
          • jajou318
            • Jan 2005
            • 1023
            Originally posted by Nick325is
            Nick
            ROFL.
            • Stu Mc
              • 4083
              About 1/4" of spacer is needed, 1/3" at most.
              Be sure the wheel is lined up straight before tightening down the 22mm
