5 pt. harness install help
  • Oolop
    • 121
    i have a corbuea fx1 pro seat and am purchasing a 5 pt harness. i dont have a cage or even bar for the shoulder harness.
    is there anyway to install the shoulder harnesses with out the use of either options said before?
    E30 LS1 swap, Tremec TKO, three link live axle rear suspension.
  • KenC
    King of Kegstands
    • 14396
    Why are you running a harness without a roll bar.
    Originally posted by Gruelius
    • 325ix
      • Aug 2009
      • 7783
      Because he doesn't care about safety. They are purely for looks.
      • MaksV
        • 1042
        how much do you care about your spine?
        CHEAP REBUILT INJECTORS
        Need Quality Brakes? BimmerBrakes has it!
        For anything Else go with BluntTech!
        • Jaxx_
          • Dec 2009
          • 1880
          walking is overrated
          • bmwguy325is
            • May 2011
            • 1263
            Yes this. If the angle is not much coming off the back of the seat you can use the rear seat belt mounting location. However I doubt the straps are long enough. For the fifth point you need to make a hole in the floor or weld in a plate to attach it to. If you want the look and still want to be safe go buy a http://www.hmsmotorsport.com/store/schroth-tuning-belts.
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • KenC
              King of Kegstands
              • 14396
              A 4-point one is fine for an open lot autocross. I wouldn't ever wear one on a track without a cage. The anti-submarine belt is to prevent you from sliding under the dash in a front end collision. You should have a cage if you're going fast enough to necessitate the 5th point.
              • 325ix
                • Aug 2009
                • 7783
                The thing is, he is using fixed back seats with the harness, which as we know, don't collapse in a roll over.
                • Oolop
                  • 121
                  i dont have a spine
                  just seeing options
