Aftermarket Light
  • MattBimmer
    • 339
    Aftermarket Light
    Does anyone know of an aftermarket dome light or map light that could go on an 87 325i sedan. The interior lights seem lacking now. Also the less intense wiring the better. Thanks
  • nicky51
    • Jan 2010
    • 158
    Reply
    Well i have a vert and its one of the first things i did.. Pep boys sells that little rectangular pad with the led lights all over it. Its about 1 inch by 2 and a half long. Its sticky on one side. I just stuck it over the dome light because mine was yellowish and i didnt care. And then just connected the 2 wires to where the existing bulb is.. Dont know if we have the same lights though.. Mine has been in for about 3 years with no problems. Took me about 5 minutes.. Hope this helps. Good luck..
    • E30m42cab
      • Aug 2009
      • 190
      Why aftermarket? Go OEM with a maplight rearview mirror. Can be had for $40-$60. Run the OEM wire harness down the A-pillar, and the connector is in the driver's side kick panel by the speaker. Pretty simple install. If you're feeling crazy, feed the wire down the inside of the A-pillar. It's not easy, but it makes for a clean install. Some people just get the power from the check panel wiring harness, but these people are butchers, and are too lazy to do real work.
      If you want to get adventurous, you could install two more dome lights into the sun visor panel by linking them to the existing dome lights.
      • JasonC
        Site Manager
        • 14451
        here's one out of a Chevy truck. But you'll lose your check panel.
        1992 BMW 325iC
        1978 Chevrolet Monte Carlo
        • unevolved
          • Nov 2011
          • 714
          Anyone have more information on what kind of Silverado light was used? I'd love to add a dome light to my car, the interior lighting is a little... non-existent... at night.
          1991 318i SOLD
          2003 325i SOLD
          Racecars and stuff.
          • FLG
            • Sep 2011
            • 3165
            Could always go with led's
            Only pic I have. There white got em from umnitza
            Sent from my Galaxy Nexus using Tapatalk 2
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
