Electric Vaders into e30
  • e30-325boy
    • 92
    quick question.
    Will electric Vaders fit in an e30? I've seen plenty of e30's with vaders but I have heard that electric ones are a no go. Anyone know?
  • kencopperwheat
    King of Kegstands
    • 14396
    If you made a bracket for them to sit high enough to clear the floor vents and don't rub the tranny tunnel in the middle, I'm sure that you could fit them.
    Originally posted by Gruelius
      • 37833
      A guy on BFC installed E36 lux seats that were power in his E30 so I'd bet you could get the power vaders in there too
      Grover Beach, California
      BimmerHeads.com
      • e30-325boy
        • 92
        yep looks like it :) Stay tuned for pics of the fitted in my car :)
        • Madhatter
          • Oct 2004
          • 966
          Jesus V, thats a tight fit.
          Just a little project im working on
          - http://www.lse30.com -
          • peteM3power
            • 450
            Would look nice if he can pull it off though!
            Pete
            • e30-325boy
              • 92
              Plan is to mount the seat with the one standard rail (the one closest to the tranny tunnel) and weld an e30 rail to the side of the other rail.
              Only other thing is getting power to them. I was just thinking of running a power wire to them with a relay in line.
              • Madhatter
                • Oct 2004
                • 966
                ooh, welding is a bit dodgy with engineers, some of them really dont like it and will give you grief over it when you want to register the vehicle. You cant remove the existing rail then make up a bracket from steel plate to use the E30 rail instead? all the bracket has to do is on one side it fits the size of the seat, then the other bolts onto the stock E30 rail (using the same bolts and spacing if possible).
                make it easier for the mod plate (i assume they have a similar system down there) than cutting and welding thats all.
                • EtaSport
                  • 2853
                  I assume they were just sitting in there for mock-up? Either that or they were all the way back. When we put the manual vaders in it was tight, and we didnt get them to sit perfectly straight. You've got to lose or modify the seat belt rail too.
                  Old and improved:
                  • e30-325boy
                    • 92
                    Cant remove the e36 rails because of the power sliders Unless it is possible to move the whole slider assembly in a bit.
                    Yeh just a mock up the seller di for me in is e30 project car. Looking at my car yesterday I relized the seat belt rail issue. What did you do with it?
                    • sticksdaman
                      • Apr 2005
                      • 2987
                      how much do vaders weigh?they look heavy
                      Originally posted by ebelements
                      Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                      • DanGillan
                        • Mar 2004
                        • 4061
                        automatic eh?
                        Dan
                        • EtaSport
                          • 2853
                          The automatic car isnt his. The seat belt issue: You can either modify the rail by shortening it and bending it. Or what we ended up doing was getting a large 3 inch U bolt. Placing it as close to the seat as possible so the belt would be close, and drilled two holes and put it in.
                          Old and improved:
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            Wow, cloth vaders look horrible. Maybe it's just that seat.
                            • Madhatter
                              • Oct 2004
                              • 966
                              outside is suede i think so you get weird patterns to it, they look a little dirty too, bet they come up fine with a clean. I wouldnt say no to a pair.
