How to Swapping Out Steering Wheel?
  • GOT8SPD
    • 270
    Hi.............
    I want to replace my factory steering wheel in my 1990 e30. Its the huge wheel with an airbag...Will the SRS light come on without the airbag in tact?
    Do I just need to buy the momo hub and new steering wheel and that's it? (from what it seems like that's it based on the things I've read)
    On Tuner Motorsport it says....
    "This hub adapter allows installation of a MOMO steering wheel (or any steering wheel that uses the 6 same bolt pattern / specs of a MOMO) to an E30 3 series or 1986-88 E28 5 series. **Modification(s) will need to be made to use this hub on cars that came with an airbag (1991 cars). Includes everything pictured -- hub, slip ring, and hardware."
    I know it says 1991 cars, but my 90 has an airbag...what mod does it need? Really hate this huge wheel so I need to get rid of it.
  • Ryann
    • 3350
    Order an extra 32311120260
    Then you'll need a Torx #27 screwdriver to unscrew the 2 screws holding the airbag center to the wheel on the back side near the hub, then unplug the orange connector, then use a 22mm socket and long ratchet to loosen the steering wheel nut, then turn your ignition key to the 'on' position, then pull the airbag wheel off, then pull out the white plastic stud from the steering column base with a violent and sudden motion [at approx. the 10 o'clock position] with some pliers, then bolt on your MOMO hub to your wheel then slip that onto the splines, then put 32311120260 over that, then put the nut on. Adjust for 12 o-clock if necessary. Done.
    • mr.vang
      • 4371
      yes srs light will pop up. just remove the bulb, no biggy. 84-89 no airbag, 90+ airbag
        • 37829
        The Momo hub will work. To get rid of the SRS light, get yourself a check panel from a non-airbag car.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • trackjunkie21
          • Jan 2010
          • 3962
          Or just disconnect the SRS computer underneath the knee bolster
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • davem
            • Jun 2010
            • 705
            Originally posted by trackjunkie21
            or just disconnect the srs computer underneath the knee bolster
            +1
            • GOT8SPD
              • 270
              LOL...so dumb...My car has other problems more critical and i'm worried about a stupid light....LOL.
