Dead Pedal
  • ACHTUNG
    • May 2005
    • 2397
    Dead Pedal
    I stripped my interior including the carpet. There is a big block of foam under the carpet that makes up the dead pedal. Since I removed it I need a new metal dead pedal. Does anyone know where I can get one that bolts in? Or do I have to have someone fab one up?
    I've read about the M-Tech dead pedal that goes for $200-$300 on ebay. I think that's freakin ridiculous.
    1989 US E30 Cammed S52
    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
  • Red325es
    • 140
    I'm looking of the same thing, I thought of maybe just fabricating one.
    • Dave
      E30 RAT
      • 11675
      Alpina makes a bolt in one - hard to find though.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • DanGillan
        • Mar 2004
        • 4061
        you can get generic e30 ///m ones on ebay for under $40 i think
        Dan
        • Nathan
          • Apr 2004
          • 671
          My "dead pedal" is the same way. As far as I know you will have to fab something up. Is most e30's the shell just comes out right there to form the backing for the pedal. Sucks becuase you can't really install an after market dead pedal correctly becuase there is nothing to really screw it into and it isn't flat.
          PNW E30 CREW ///
          • Jand3rson
            • 37587
            I'm considering removing the block of stryofoam, and replacing with a chunk of wood or plastic, and anchoring it down somehow. I step on the dead pedal hard when I'm adjusting myself in my seat and other times, and it gives a lot, even with the dead pedal I have on there, one of the ebay ones. I just have it screwed into the styrofoam block, and it does pretty well.
            • ACHTUNG
              • May 2005
              • 2397
              I guess I'm going to have to Fab one up. I have a good friend with a TIG welder. I'm thinking that diamond plate will be good. I'll post some pics once I have it made and installed.
              • NC325iC
                • Mar 2004
                • 6565
                hahaha... unintentional rhymes make me laugh
                • ACHTUNG
                  • May 2005
                  • 2397
