Momo horn button install
  • Mr. Burns
    • Aug 2011
    • 3516
    Yep, searched. Found nothing.
    Have a momo champion, and momo hub.
    Took oem wheel off and horn wires are built into wheel, there is a pin on the oem hub.
    How do I make this work?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Mr. Burns
    • Aug 2011
    • 3516
    bump for incompetence.
    • PNWDan
      • Feb 2011
      • 1326
      post pics of what your working with
      1987 Alpinweiß 325is
      Like the PNW E30 Local Crew Facebook page
      • noE30
        • Jun 2008
        • 2260
        I have mine hooked up on my momo monte carlo. I might be able to get you pics tonight of how its setup.
        Flickr
        @michael.colby on Instagram
        "All he needed was a wheel in his hand and four on the road"
        • ttrousdell
          • Nov 2009
          • 1770
          When I installed my wheel i never had to modify any wires. Just put the wheel on and attach the horn button to the wheel via the two wires and put the horn button in place
          The Build:
          • M-technik-3
            • 18946
            One wire from the pin to the horn button
            • 110stx
              • Sep 2011
              • 253
              Run ground lead from horn button to one of the bolts that hold the wheel to the hub adapter.
              Metal ring around horn button to make constant contact with hub adapter.
              Done.
              Hell no, I don't get it. But it works. :-)
              STX e30
              No. 10/110 STX: 1989 325i
              DD: 1991 318is slicktop
              SHAZAM, GOMER, LOOK AHEAD.
              • Simon S
                • Oct 2004
                • 3758
                -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  I had a sport steering wheel in my vert...all wires where built in, nothing to detach from the oem hub.
                  on my momo hub, I have the 1 ground and a positive lead
                  but knowhere to attach them.
                  the suggestion that 110STX mentioned sounds like the most feasable one, I'll give it a shot tonight.
                  thanks guys
                  • th3blue
                    • 114
                    I needed this same info... thanks.
                    1997 BMW 328ic 5spd sport Moreagrun Metallic
                    1989 BMW 325is 5spd with a M50 swap
                    2006 Audi A3 6spd DSG sport with APR stg 2
                    • jrobie79
                      • Mar 2006
                      • 2526
                      i bought a new momo race wheel and new hub...took my old mtech off. connected the horn button to the metal ring that goes in between then wheel and the hub. there is another tab on the metal ring which accepts the wire from the horn.
                      1991 318i ---- 308K - retired
                      • LJ851
                        • 7919
                        The horn works by grounding the wire that comes from the spring loaded pin in the hub.
                        The steering wheel and steering column are grounded to the chassis.
                        The momo horn switch is a simple momentary push button switch.
                        The wire from the spring loaded pin (12v positive) goes on one terminal on the back of the horn button.
                        The other terminal on the back of the horn button needs a wire going from itself to somewhere on a metal part of the steering wheel or hub (ground).
                        Lorin
                        The M30 is God's engine.
                        • moreoff
                          • Apr 2007
                          • 516
                          yay just what i need to know! using momo wheel w/ sparco hub
                          i'm using a sparco hub that only had the positive, but no ground.
                          so i made a ground wire from the momo horn button to wheel bolts
                          My Build Thread
                          My Transaction Feedback
