sunrook crank handle issues
  • RUFFLZ
    • Apr 2011
    • 3122
    Ordered one off bma to replace the finicky one I currently have, but for some reason I can't get it to sit right.
    I then went ahead and tried the old one and it fit's like a glove.
    I even tried tapping w/ a rubber mallet to no profit.
    help meh guise
  • Swanny
    • Mar 2012
    • 2834
    I love the crank roofs. Looks like you're having a rodeo party in the car when you use it. Woot woot
    No help though.
    Swanny!
    SUCKERS.
    • F34R
      sLaughter
      • 12376
      Bigger hammer, or a blow torch. That is how I get things to fit in tight places. Or lube...
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • RUFFLZ
        • Apr 2011
        • 3122
        I'm afraid last night's fesitivites of elephant walking used up all le lube :(
        aaaaaand
        If I pound any harder, the plastic piece will probably break.
        maybe I could shave a bit off on the inside
        • Vivek
          attention whore/retard/bitch
          • 6167
          Did you check for any visible differences between the two pieces?
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • 85bim
            • Jan 2011
            • 92
            I had the same problem with the one I ordered a while back. Never did get it to fit, you could see that it was smaller because the inside of the metal piece was denting in. it isn't much that its too small but just enough that it will never go on. I just ended up getting one off a car someone was parting out and it popped right on like it should...
            I think there must be two sizes or maybe someone is just manufacturing them wrong?
            Hope this helps kinda :-)
            • Spyke
              • Sep 2012
              • 494
              I got one off eBay and had the same issue. The problem was that the inner hole was jut barely too small to allow it to slip in place like the original. I used a small cylindrical file to widen the insides. Once I got it close enough, I was able to tap it on in small increments with a hammer, took it off, repeated a dozen times, and it shaved the remainder by itself and was able to fit. Really annoying to have to do, but it works perfect now, really snug.
              Current_SeeDee 1972 e10 Luna 1975 e10
              Past___Veronica 1994 e36 Le-Ah 1987 e30
              • IAmGary
                • Apr 2012
                • 183
                I've been collecting sunroof handles (I have 4) and I've never, ever found one that fits over the crank post in my car. Even from the same year, my post is too big for the replacement crank to fit.
                They look pretty similar, but just won't fit.
                • AntiScope
                  • 401
                  No help though.
                  HAHA people always stare at me like "What the FUCK is he doing right now.."
                  • Andy.B
                    • Sep 2011
                    • 1650
                    the reproduction pieces are slightly off. Just file it out, or search for an oe handle.
                    Sent from my Galaxy Nexus
                    • wikkid
                      • Aug 2012
                      • 113
                      Excuse my noobness on this,but are we talking about the knob for the crank? I have a perfectly working crank mechanism, but the crank handle is missing the knob that you would normally hold to turn it. Is this a common thing?
                      • RUFFLZ
                        • Apr 2011
                        • 3122
                        yes derpvik
                        Yeah there is a negligible difference between the two, enough to make it not work
                        think I'm gonna have to shave the inside of mine with a thin file/sandpaper as well.
                        I feel it
                        :p
                        gonna do this when I have time
                        nah, talkin bout the whole crank (metal assembly), not the black knob
