So everything on my cluster except the odometer was working correctly, then after removing the battery and giving the engine bay a clean, I now have the L/100kms through the roof, the tacho only goes to 2500, and the speedo doesn't work. I've removed the cluster and specifically the tacho, and when you move the needle up it has a physical resistance when you get to 2500, then if you push it over that, it wont drop back past it unless you push it back over that hard spot. Any help would be appreciated on this as its doing my head in!
How screwed is my cluster?
Yeah I've been thinking about it! I'm a bit hesitant to start playing around with gears under the tacho as I don't have much experience, and the speedo seems to be an electrical problem which sucks! But ill have a look tonight and post up if I make any progress/make matters worse haha!sigpic
samfg92
Originally posted by ak-The Best mod is a clean car.Comment
