leaking water
  • samstrimbu
    • Dec 2012
    • 10
    leaking water
    Every time it rains i get a huge puddle of water that collects in the trunk. i replaced the seals for the trunk and the rear tail light but it is still filling up with water when it rains.
  • Vivek
    attention whore/retard/bitch
    • 6167
    Antenna or sunroof drains most likely.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • ELVA164
      • 4861
      ^These are the most common sources, but if the water appears to collect under the jack or battery, check the breather covers on the sides of the trunk:
      http://www.realoem.com/bmw/showparts...51&fg=15&hl=15
      • ZM Blue Devil
        • Dec 2006
        • 13836
        Id bet on the windsail grommets/seals. easy to test, just hold a hose to the sails while trunk open carpet out and see if coming down from the upper side.
        We have also recently repaired two cars where the rear windshield gasket had shrunk/installed properly.
        Levent
        %20levent@gutenparts.com
        Ladies:
