steering wheel removal
  • Skunkworks
    • Sep 2012
    • 436
    I was at pick a part today, and watched a guy battle a steering wheel for an hour, I took a look and it didnt appear to have anything holding it on, I just wobbled around on the steering shaft, Do they have a clip in the rear? what its the procedure for removing a non airbag wheel?
  • e30jake
    • Feb 2012
    • 855
    Steering lock was probably holding it on. I'm guessing the key wasn't in it?
    What it feels like owning an e30:
    88 325 S50 swap in progress
    90 325ix
    • Holland
      • Nov 2008
      • 7212
      Steering lock.
      Originally posted by DEV0 E30
      • jdirty
        • 346
        This might be OT.. but how do i remove an airbag wheel if the 1 out of the allen bolts in the back are rounded off..? Suggestions?
        • Skunkworks
          • Sep 2012
          • 436
          yea key was out. makes sense now.
          • ELVA164
            • 4861
            Use a star drive socket a bit larger than the allen head, tap it in with a hammer, and remove.
            • 2furiousd
              • Jun 2012
              • 37
              I know this is likely a little late, but I just removed one from a locked wheel at the Pick N Pull. I used a hacksaw. Cut right behind the wheel, and it took about 30 seconds. Came right off. $12 MTech wheel was mine.
