Dash Instal, While I'm In There Jobs?
  • deutschman
    • May 2008
    • 5958
    I am replacing my dash with a much nicer dash in the next few weeks.
    Are there any "while your in there" jobs I should consider. Replacing the dash is a bit of work, and if there is anything behind it I should consider replacing I think nows a good time to do it.
    Cheers guys
  • I*Do*Werke
    • Dec 2010
    • 259
    light bulbs for the a/c and definitely get new foam gaskets for the air vents. They are most likely rotted
    ^M52B28^
    • deutschman
      • May 2008
      • 5958
      Will do. Thanks
      • efficient
        • Feb 2012
        • 3312
        Blower fan. Clean grounds.
        • george graves
          • 19998
          Do yourself a favor and add a terminal block. Tap into Constant power, ground, ACC and illumination off the radio harness. Makes installing gauges, and what not much easier in the future if you've got access to it.
          Originally posted by Matt-B
