Interior lights flashing or bumps/cornering
  • Max399
    • Feb 2013
    • 991
    Hello guys, a i got a little problem. When cornering, or coming over bumps - my interior lights flash, just like a door would open. What could be the problem, where should i start searching? Thank you.
    5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
    Leave feedback about my transactions!
  • Semblance
    • Jan 2011
    • 433
    Sounds like a bad door switch
    '89 lachssilber vert - Frau Blücher
    '84 alpine 2dr - gone to the great beyond...
    '00 titanium 4dr e46 - bricked
    • Max399
      • Feb 2013
      • 991
      Is there some easy way to check them, and locate which one died? Or i just wiggle them and check with a multimeter? Thank you.
      • Sindako
        • Nov 2012
        • 116
        Bad Door Switch , or Door Switch Wiring
        • Semblance
          • Jan 2011
          • 433
          You could remove one and drive for a while. If the problem goes away, you've found the bad switch. switch is on the body just above the lower door hinge, pry out. Check this for pics:
          .You'll have to find a way to keep the wires from falling back into the body, tape maybe.
          • Semblance
            • Jan 2011
            • 433
            If you pull them all and still have a problem, you have a short.
            • Max399
              • Feb 2013
              • 991
              Found the problem. It was the trunk switch not reaching the plastic cover on the boot. Little lift and its good. Easyest way to find which one is bad is to try them all in the dark :)
