did you delete your sunroof and install a headliner?
  • oliver.r
    • Mar 2012
    • 3839
    If so I need your help!
    I deleted my sun roof and cassette so now I don't have a way to keep the rods up, they just flip down so my headliner seems a bit lower then it should be.
    how did you keep the rods from flipping up side down?
    theyre originally retained with metal tabs on to the cassette which I no longer have.
    thanks for the help!
  • oliver.r
    • Mar 2012
    • 3839
    Bump
    • DIIRTY-30
      • 1665
      Can you elaborate on what you mean by the rods?
      I'm trying to picture it in my head but having a hard time.
      BLUE NOSE - M62 SWAP
      THE E30 + 1 BUILD
      • oliver.r
        • Mar 2012
        • 3839
        Yea, the cloth headliner has rods going through it horizontally from one side of the roof to the other, they are what keeps the headliner up, hope that helps
        • rickycricketts
          • 806
          How did you reinforce the front of the roof? I just took my cassette out and also would like to know how others are doing their headliner. I'm contemplating shaping my own foam and gluing it into place. Then I can glue the headliner to that.
          Sent from my Desire HD using Tapatalk 2
          • oliver.r
            • Mar 2012
            • 3839
            im not sure what you mean by reinforce the front of the roof, I left the sunroof intact, didn't skin it, used that for support and welded it all in
            • DesertBMW
              • Aug 2011
              • 1042
              I deleted sunroof on 3 E30s, main reason is because you simply can't buy replacement parts, and no one makes aftermarket sunroof parts.
              On first E30, I removed the whole sunroof system including the shell that is tack welded to the roof, then I attempted to weld the sunroof top to rest of the roof, but the weld started wrinkling the roof. So it became a mess, then I had to cut the panel off at the welds then weld a support inside then weld the support, then use urethane windshield installation compound and seal the opening, it came out ok.
              On two others, I did not remove the cassette part, and welded 4 bolts to the cover, then drilled 4 holes down on the cassette then bolt the cover down, then use urethane sealant and it came out looking slick,
              • Robert
                • Dec 2010
                • 3770
                Sorry if this is off topic.
                What are you going to use to make the roof smooth? I deleted my sun roof and removed the cassette, I also skinned the original sunroof panel & weleded a 1/4th inch piece of solid tubing around the whole cassette to fill the gap in some what. I then tack welded the skinned panel in. Now here is the hard part, how do you smooth out the top of the roof w/o using so much bondo (that will eventually crack).
                I planning on getting a new headliner put in, i don't think its worth using the stock OEM one. Its probably easier to just get one glued in.
                • oliver.r
                  • Mar 2012
                  • 3839
